Flex6400M: Only gets Connection (Waterfall/Receiving) after second reboot
snet0311
Hi,
i have to restart my 6400M always one mor time after i switched on the radio, to get full access to the receiver. Waterfall is "black", Spectrum visible, but no incoming signals to see or heard.
After the Restart all is OK.
73', Stefan
73', Stefan
This would be best resolved by following up with a support ticket. They can help you out.
Hi Mike. Unfortunately it was not possible to sign in for a ticket without a registration for the „Technical Support“ first. I did‘t find any option to register. So i‘ve done some further research about the problem. It‘s solved! The powering up and down with a delay was the solution. Done so, now it‘s working. 73‘, Stefan0
Yes, you will have to register to log a ticket.
Upper right corner
Next
The Devil is in the Details. „Sign In“, „Sign Up“ first 🥲😉0
I just was receiving all red in place of my water falls on 20m and all
black on 40m?
Hi Frank, I would suggest that you export your profiles, then do a factory reset. If that doesn't help, submit a help desk ticket.
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 270 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
