Can I use the second receiver on 6600M for receive loop antenna?
angelo
Hi,
Please, If I'm using a vertical antenna, which is noisy, and I want to add a receive loop or bog, to get better reception, is this supported on the 6600M radio?
Yes.
In fact, you can use it on the first slice.
Connect your receiving antenna to RXA (BNC) and then in SmartSDR you can chose when antenna your want to receive on (Blue letters). Red letters are the transmit antenna.
You could even add up to 3 more receiving antennas if you like and use RXB, XVTRa and XVTRb. And, still only open 1 slice if you like.
Make sense?
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
