Can I use the second receiver on 6600M for receive loop antenna?
angelo
Hi,
Please, If I'm using a vertical antenna, which is noisy, and I want to add a receive loop or bog, to get better reception, is this supported on the 6600M radio?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYes.
In fact, you can use it on the first slice.
Connect your receiving antenna to RXA (BNC) and then in SmartSDR you can chose when antenna your want to receive on (Blue letters). Red letters are the transmit antenna.
You could even add up to 3 more receiving antennas if you like and use RXB, XVTRa and XVTRb. And, still only open 1 slice if you like.
Make sense?
- 111 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
