SO2V Flex 6400 & N1MM
Hello everyone,
I have configured my Flex 6400 & N1MM for SO2V, it works well because the two "Entry Windows" appear, each "Entry window" has the correct slice frequency.
When I press the "/ Key" it changes the focus between the "Entry Windows" but does not change the TX from one Slice to the other slice
How can I make pressing "/ key" also change the TX from one slice to the other slice?
On the other hand: I have created a macro for F11 that changes TX from one slaice to the other slice, this works fine but I would like to do it with "/ key" not with F11
F11 Macro:
A | B, {JUMPRXTX} {CAT1ASC ZZFT;} | {JUMPRXTX} {CAT2ASC ZZFT;}
Can somebody help me?
Thanks in advance
73´s Ignacio, EA4OR.
[{"insert":"Hi Ignacio, did you get your issue solved? I am facing the same problem...\n"}]0
I got CW transit to follow the active slide by
- Setting the Slice Options in SmartSDR to "Always make active slide the TX slice" and;
- In N1MM+ Configure->Set for the two Flex COM ports setting the "PTT via Radio Command CW Mode"
I happen to use the MacOS version of SmartSDR but suspect that the Win version can work the same way.
Now, CW transmit follows the active Slide when you use "\" in N1MM+ to change receivers... Almost as good as two radios!
For all 6000 series FlexRadios do not set it up as SO2V in N1MM as you will struggle with it.
You need to set it up as SO2R.
While this says 6700 it is valid for all radios.
When you do it this way, the radio behaves as expected.
Thanks for your answers and info
- 342 Community Topics
- 611 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 406 SmartSDR for Mac
- 265 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 197 FLEX-8000 Signature Series
- 919 Maestro
- 889 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 965 Third-Party Software
