Not Seeing Power or SWR Meter Activity When Transmitting with Heil HM-10-XD on 6600
Just a thought. Have you made the correct selection on the side-screen of the ssdr display as to which type of input you are using?
The selection includes Mic, Bal,Line, Acc. If you have not selected the correct one (I think it would be Acc in your case) then you will appear to transmit, but nothing will happen on the display. I have been caught out by this before, myself. I use Bal, as I have a Heil mic and plug it into the 1/4" TRS socket at the rear. Not sure if you also have to click on "+acc" as well. I am using SSDR for Mac, so you might have slightly different display....
Good luck. Hope you sort it easily.
73 de Mike G4GWH
Hi Mike,
Thank you. I have the Mic selected since I'm using the standard mic and PTT ports on the back of the 6600. I did test your suggestion. I get no response anywhere. With my current config with the Heil mic I do get an increased amplitude on the panadapter waveform when I key up and speak.0 -
Hmmm...I just had the thought to turn off Slicer 6000 and for the moment it appears to have solved the issue. I had Slicer config for FT4 and Log4OM. Since I'm using them, do I need to configure something in Slicer for the new mic, adapter, and PTT footswitch?0
When using ft4, is the flex set to digiu or digil? When using the mic, is usb or lsb selected?
It helps if you show a screen shot of SmartSDR with it failing. 99% of the time, we can see what is wrong right away.
Hi John, It's working fine with digital modes. No issues. The issue is with the Heil mic using the Flex Radio adapter.0 -
> @Mike-VA3MW said:
> @N4RFX
Mike, I have two short video files to demo the issue. How do I get them to you? I don't see a way to attach to these comments. E-mail to you?0 -
@VA3MW
Mike, could this simply be a bad Flex Radio adapter (ACC-4PXLR-TRS (4 Pin XLR to 1/8in (3.5mm) TRS and RCA for FLEX-6400(M) or FLEX-6600(M))0 -
Check the adapter with an Ohmmeter?
Not sure. I would suggest you get a support ticket opened and then they can work through it with you.
Thanks, everyone, got it all sorted out thanks to Ken at Flex Radio Support. Working well.0
What was it? The details might help someone else.
@AB6BT
Here's what was recommended:
For the Heil Mic, which is a dynamic Mic, you do NOT need to have the BIAS enabled in the Mic Profile.
You DO need the +20 Mic Preamp.
I noticed that you are getting a little deflection on the Mic LEVEL Meter with the Heil mic, but it is not high enough.
Adjust the Mic Gain Slider until the PEAK indicator on the LEVEL meter reaches to about -5 on the meter.
( Have circled the Mic Gain slider, which is where I have mine set for my Heil PR22UT mic)
NOTE: The LEVEL meter has a dual indicator.
The Solid Bar is the AVERAGE level indicator.
The Little Line that dances ahead of the solid bar is the PEAK indicator.
Use the PEAK Indicator to adjust your Mic Level.
(I have an arrow on the picture to indicate the PEAK indicator)
For these Heil Mics you may need to set the Mic Gain slider to as high as 80-90 or so.
Note: I am getting a good level of Compression, because I am using the DX+ setting for COMP.1
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
