Driving relay with TX1-TX3
normancyyj
I would like to use TX1 to operate a relay that will be used to switch an antenna. Will I need to put a clamping diode across the coil and what is the maximum current that TX1-TX3 will sink?
I would use a clamp diode across the relay coil.
From page 26 of the "Hardware Reference Manual": The TX Relay outputs are designed to handle signaling levels of up to +40 VDC @ 140 mA maximum.
Gayle K0FLY
Thanks for your response. I intend to switch in different antennas for transmit on different bands when operating remotely on antenna 20
- 391 Community Topics
- 665 The Flea Market
- 165 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
