Driving relay with TX1-TX3
I would like to use TX1 to operate a relay that will be used to switch an antenna. Will I need to put a clamping diode across the coil and what is the maximum current that TX1-TX3 will sink?
  • K0FLY
    K0FLY Member ✭✭✭
    I would use a clamp diode across the relay coil.
    From page 26 of the "Hardware Reference Manual": The TX Relay outputs are designed to handle signaling levels of up to +40 VDC @ 140 mA maximum.
    Gayle K0FLY
  • normancyyj
    normancyyj Member ✭✭
    Thanks for your response. I intend to switch in different antennas for transmit on different bands when operating remotely on antenna 2
