Driving relay with TX1-TX3
normancyyj
I would like to use TX1 to operate a relay that will be used to switch an antenna. Will I need to put a clamping diode across the coil and what is the maximum current that TX1-TX3 will sink?
I would use a clamp diode across the relay coil.
From page 26 of the "Hardware Reference Manual": The TX Relay outputs are designed to handle signaling levels of up to +40 VDC @ 140 mA maximum.
Gayle K0FLY
Thanks for your response. I intend to switch in different antennas for transmit on different bands when operating remotely on antenna 20
- 650 The Flea Market
- 152 SmartSDR+
- 263 SmartSDR CAT
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
