SmartSDR CAT v2.7.6.3372 Unhandled Error Message
I keep getting multiple,stacked, unhandled error messages since upgrading to SmartSDR v2.7.6.3372
See Windows 10 message below.
I am running the Flex 6600M from the front panel and not using the PC GUI.
Running v2.7.6.3372 on the radio and front panel with Windows 10 OS build 19042.1110
I need to restart CAT to clear the problem.
Geoff - W8GNM
This sounds very similar to problems with earlier versions when there was a CAT port interference problem. If I remember correctly, the best solution was to completely uninstall SSDR, including VSP (if that's still a thing -- sorry, I'm not able to update to the latest version just yet), then restart the PC (to make sure the registry is cleaned up, etc.) then do a fresh re-install of SSDR including VSP, when requested.
Please open a support ticket before you run down the un-install/re-install path.
- 391 Community Topics
- 665 The Flea Market
- 166 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
