SmartSDR CAT v2.7.6.3372 Unhandled Error Message
I keep getting multiple,stacked, unhandled error messages since upgrading to SmartSDR v2.7.6.3372
See Windows 10 message below.
I am running the Flex 6600M from the front panel and not using the PC GUI.
Running v2.7.6.3372 on the radio and front panel with Windows 10 OS build 19042.1110
I need to restart CAT to clear the problem.
Geoff - W8GNM
This sounds very similar to problems with earlier versions when there was a CAT port interference problem. If I remember correctly, the best solution was to completely uninstall SSDR, including VSP (if that's still a thing -- sorry, I'm not able to update to the latest version just yet), then restart the PC (to make sure the registry is cleaned up, etc.) then do a fresh re-install of SSDR including VSP, when requested.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsPlease open a support ticket before you run down the un-install/re-install path.
- 684 The Flea Market
