SmartSDR for Mac SmartLink FT8
Hi,
I am operating remotely with my Flex 6400M and SmartSDR for Mac, using SmartLink connection and mode FT8. When I transmit there are some random spikes on my TX. I have no other program running. I believe it's some kind of interference on the audio but I don't know if it is related to my MacBook Pro or the Flex itself.
See picture attached.
Paulo
The only way to tell would be to listen to your transmitted signal. Put the radio into Full Duplex mode and listen on a 2nd receiver at the same time.
Thanks Mike.
I found that it is somewhat related to my Multi-port USB-C Hub. When using WiFi I don't have the interference. When I plug my USB-C Hub and use an Ethernet connection the interference shows up.
73 Paulo
I think I'll need a galvanic isolator.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
