When two transverters are fitted is it possible lock vfo A and vfo B together. A on 144mhz, b 432mh
Bernard Collins
Member ✭
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYes, I think using FRStack.
The question is why would you want to do that?
If for Satellite use, you will not be happy with the result since the radio will not track doppler correctly and you won't follow AMSATS "one true rule" for satellite operation. https://www.amsat.org/tag/tuning/#:~:text=The%20One%20True%20Rule%3A%20tune,the%20end%20of%20the%20transponder.
It would be best if you used something like SATPC32 on Windows or MacDoppler on MAC to ensure a much more seamless operation.
If there is some other reason, I would be interested in hearing about it.
Set up Slice B tracks Slice A from the "Radio" menu on FRStack.
Alan. WA9WUD
[{"insert":"Thank you Mike for the solution, I will try it out tomorrow as I have a zoom radio club meeting tonight.\nIt is for Satilite use, but for Q0-100 geostationary. I currently convert on receiving dish 10ghz to its if of 739 then to 144mhz, I tx on 432mhz to an up converter to 2.4ghz dish and an amplifier nominal 20 watt but need a lot less. This is all working via another radio but the flex will give me a better display but I will have to check stability. \non vfo A I will tune to a set usb frequency then tune vfo B to the same by hearing myself coming back down the link then lock B to follow\n Vfo from then on. Hopefully.\n I have only had the flex 6600m for a few weeks lots to learn and enjoy.\nThanks again for your help\nregards\nBernie MW0GBW \n\n"}]0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThanks Alan
I had forgotten that he added 'reverse' and for Q0-100 the world is different.
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
