Having a Problem with slice master following the flex Frequency on CWskimmer
Ron Rosson
Thought I had it all together. Then something change between slice master and CW Skimmer it decodes find but does not follow Frequency on The Flex 6500. I'm trying to decide whether it a setting CW Skimmer or Slice master. If anyone has any ideas how I can resolve this issue. TIA
Hi Ron,
On the last tab of SliceMaster, do you have your radio selected?
Here are my settings they are not the same it does show 6500 Btw I can't find how to add attachment so I can show my Slicemaster layout.1
Here are my settings on Slicemaster
I see at the bottom that it found your Flex.
In CW Skimmer under View Settings... Radio tab, select SoftRock and the CW pitch that you have chosen in SmartSDR for your 6500. Select a Sampling Rate of 48 kHz.
Make sure DAX is on and has a matching sample rate:
It has been a long long time since I set this all up, but I don't remember doing anything else to get it to follow my frequency excursions.
Hopefully this is enough info to get you going.
Len,
These are the setting i have and they seem to be working for me now. Thanks for the guidance to get me on the right path..
Glad you got it working Ron!
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
