SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Having a Problem with slice master following the flex Frequency on CWskimmer
Hi Ron,
On the last tab of SliceMaster, do you have your radio selected?
Here are my settings they are not the same it does show 6500 Btw I can't find how to add attachment so I can show my Slicemaster layout.1
Here are my settings on Slicemaster
I see at the bottom that it found your Flex.
In CW Skimmer under View Settings... Radio tab, select SoftRock and the CW pitch that you have chosen in SmartSDR for your 6500. Select a Sampling Rate of 48 kHz.
Make sure DAX is on and has a matching sample rate:
It has been a long long time since I set this all up, but I don't remember doing anything else to get it to follow my frequency excursions.
Hopefully this is enough info to get you going.
Len,
These are the setting i have and they seem to be working for me now. Thanks for the guidance to get me on the right path..
Glad you got it working Ron!
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
