PGXL firmware failure
Les Brown
I was just starting this afternoon's CWT session and the PGXL complained saying that it failed the firmware test. The problem went away when I turned the power off and on again. Has anyone else seen this problem or know what would cause it? I could not get the problem to stop by trying to toggle between standby and operate with the PGXL utility program. Is there any other way to force a reboot of the PGXL short of toggling the power? This is particularly inconvenient for remote operation. Do I have to build a remote controlled 240v 20A relay to toggle the power? If so, can anyone recommend a commercially available internet controlled switch for 240v?
73, Les VE3NNT
I converted this to a support ticket.
This discussion has been closed.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
