S Meter peaks to max.
I have noticed so far on two instances that my S meter peaks to max although the signal I'm listening to is not that strong. So far I have noticed this once on 15 meters and once on 20 meters. And no indication in the waterfall as to a strong signal.
I have a Flex-6300 running 3.2.67
Win 10.
Jay n2gq
I had this on my SSDR for Mac, and 6600m. Marcus advised just close down SSDR software, re-start the app, and off you go again. Worked like a charm! Worth a try with your gear?
73 de G4GWH Mike.
HI Ed.
I am running 3.2.37 is the latest I have installed. I had stated the hardware version.
It just happens momentarily. It never requires me to reset. I never seen this happen to my 6300.
Hi Ed
I just updated to 3.2.39. I will keep an eye on the meter see if that fixed it. I was talking to my buddy in Pensacola Fl.the other day and he seemed to peak to 60 over. I said wow conditions must be good 😀 then It happened again on the other band.
Jay n2gq
Hi Ed
I thought I saw the peak in s meter but not sure. Will keep checking.
Jay n2gq
This is a known and documented bug.
It does not impact any operational issues and is just a visual concern.
Mike,
Thanks for letting us know that this bug is documented! I have noticed it also with the latest firmware installs
Dave
No idea of what causes the condition, but shutting everything down including powering down both the radio and the computer fixes the problem. I have only seen this condition twice in last 6 years.
This is a software bug. It will likely come back if the right conditions happen.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
