S Meter peaks to max.
Jay
Jay Member ✭✭
edited June 2021 in SmartSDR for Windows
I have noticed so far on two instances that my S meter peaks to max although the signal I'm listening to is not that strong. So far I have noticed this once on 15 meters and once on 20 meters. And no indication in the waterfall as to a strong signal.
I have a Flex-6300 running 3.2.67
Win 10.
Jay n2gq
  • ka9ees
    ka9ees Member ✭✭✭
    @Jay I don't know what 3.2.67 is. I have 3.2.39 running on my 6400M. I have seen this phenomena quite frequently.
  • Mike Steventon
    Mike Steventon Member ✭✭✭
    I had this on my SSDR for Mac, and 6600m. Marcus advised just close down SSDR software, re-start the app, and off you go again. Worked like a charm! Worth a try with your gear?
    73 de G4GWH Mike.
  • Jay
    Jay Member ✭✭
    HI Ed.
    I am running 3.2.37 is the latest I have installed. I had stated the hardware version.
    It just happens momentarily. It never requires me to reset. I never seen this happen to my 6300.
  • ka9ees
    ka9ees Member ✭✭✭
    @Jay Same here. I would download and install 3.2.39. It's been very stable for me. Except that little glitch.
  • Jay
    Jay Member ✭✭
    Hi Ed
    I just updated to 3.2.39. I will keep an eye on the meter see if that fixed it. I was talking to my buddy in Pensacola Fl.the other day and he seemed to peak to 60 over. I said wow conditions must be good 😀 then It happened again on the other band.
    Jay n2gq
  • ka9ees
    ka9ees Member ✭✭✭
    @Jay It's still there in 3.2.39, but it's just a little glitch. Other than that the meter works as well as it should. The software behaves as I think it should.
  • Jay
    Jay Member ✭✭
    Hi Ed
    I thought I saw the peak in s meter but not sure. Will keep checking.
    Jay n2gq
  • ka9ees
    ka9ees Member ✭✭✭
    @Jay I've seen it quite a bit.
    This is a known and documented bug.
    It does not impact any operational issues and is just a visual concern.
  • Dave K5OZ
    Dave K5OZ Member ✭✭
    Mike,
    Thanks for letting us know that this bug is documented! I have noticed it also with the latest firmware installs
    Dave
  • Patrick
    Patrick Member ✭✭✭
    No idea of what causes the condition, but shutting everything down including powering down both the radio and the computer fixes the problem. I have only seen this condition twice in last 6 years.
    This is a software bug. It will likely come back if the right conditions happen.
