SW3.2.39, USB to parallel still alive after power down
Holger Hannemann
Holger Hannemann Member ✭✭
edited June 2021 in SmartSDR for Windows
Hi
I use a USB to parallel cable to indicate the band to my BCD-Decimal decoder for antenna/filter switching.
Since the update to 3.2.39 the FLEX-6600M output for this cable switches to the 80 m equivalent setting when powered off. This is an unwanted behavior. How can this be eliminated? I don't switch off the 12 V dc supply from the radio as this is needed for other devices.
73 Holger
    @Holger Hannemann
    If you can confirm this did not happen before 3.2.39 and also confirm that settings were identical, that would be helpful.
    I'll open a support ticket for you.
  • Holger Hannemann
    Hi Mike
    Yes, I can confirm this. The same hardware was in use before and switching off the radio with the front button only would also switch off the USB --> no output. This released antennas used for the skimmers running on our site. Since update to 3.2.39 the USB output is locking in the 80 m position.
    73 Holger
    I think Dan is looking at your ticket, so please pass that on to him.
