Band 60m in EU
Roman Gładysz
Roman Gładysz Member, Unconfirmed
edited June 2021 in SmartSDR for Windows
Hello everyone, I am Roman SP9FOW. For several days I have been learning how to use the Flex-6400m radio. My SN radio #: 2220-5805-6401-5464 is made by the region: USA. I would like to access the 60m band frequency in the EU.
Apparently you need a file for EU6. How can I get it?
Yours sincerely, Roman SP9FOW.
  • Erik Carling EI4KF
    edited June 2021
    Open a support ticket. I had to do this for my new 6400M because 60m was not enabled for Ireland. I was sent a TURF File the next day. It comes with instructions for importing to SmartSDR.
    edited June 2021
    Often, when you can't TX on 60M, your transmit bandwidth is not set correctly. Make sure your VFO is set correctly for your country and that your LPF for Audio is 2800hz or less.
