Can I setup smartlink without a ptt
G4YDO
Can I setup smartlink without a ptt? i'm trying to register smartlink when hit register it asking me to press the ptt but i just use the mox button or vox. is the anyway round this or have i got make up a wired ptt to register?
No. You must have physical access to the radio to register it to an account. Pressing a hardware PTT or taping the paddles will suffice for the registration process. This is a security measure to prevent your radio from being hijacked.0
You can also use your CW key.0
Or even the mike ptt.
Doug g4ovr
Front mic PTT, rear RCA PTT, accessory connector PTT, or CW key. Dave wo2x0
This is not working for me using SmartSDR on Mac. As you can see in the screenshots above, I click Register, then key up the mic. I get "Waiting on SmartLink Confirmation..." then after a while, the following window appears with Registered set to "No."
What gives?
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
