Can I setup smartlink without a ptt
G4YDO
G4YDO Member ✭✭
Can I setup smartlink without a ptt? i'm trying to register smartlink when hit register it asking me to press the ptt but i just use the mox  button or vox. is the anyway round this or have i got make up a wired ptt to register?
    edited August 2017
    No.  You must have physical access to the radio to register it to an account.  Pressing a hardware PTT or taping the paddles will suffice for the registration process.  This is a security measure to prevent your radio from being hijacked.
  • George KF2T
    George KF2T Member ✭✭✭
    You can also use your CW key.
  • Douglas Fillingham
    edited August 2017
    Or even the mike ptt.
    Doug g4ovr
  • David Decoons, wo2x
    edited August 2017
    Front mic PTT, rear RCA PTT, accessory connector PTT, or CW key. Dave wo2x
  • K5BGP
    K5BGP Member ✭✭
    Screen Shot 2021-06-17 at 8.40.24 PM.png Screen Shot 2021-06-17 at 8.40.29 PM.png
    This is not working for me using SmartSDR on Mac. As you can see in the screenshots above, I click Register, then key up the mic. I get "Waiting on SmartLink Confirmation..." then after a while, the following window appears with Registered set to "No."
    What gives?
    @KF5HEL
    Just to confirm, is the MIC physically plugged into the radio? Or a CW Key?
