SmartSDR CAT restore?
g0mfr
in SmartSDR API
Hi Folks,
My PC had a hiccup and rebooted itself - when it came back up all my SmartSDR CAT config had gone (winkey/n1mm/wsjt/skimmer etc).
Is my config stored somewhere that I can restore it from otherwise looks like I'm configuring it again from scratch?
73 Gareth G0MFR
73 Gareth G0MFR
Best Answers
If you have been backing up, you can restore from C:\Users\computer-name\AppData\Roaming\FlexRadio Systems\CAT.settings and if you have not then check this folder in the hope that the original settings file has been renamed and still exists.
I forgot to say that you can also try a System Restore to a point before the unwanted reboot. That may recover the original file if it does not exist in backup or in the actual folder.
Thanks a lot Erik! I didn't have a backup CAT.settings folder. I did consider a system restore but figured it would be easier to just set everything up again from scratch. It was a lot easier second time round hihi I am now fully working again and have taken a backup of my settings!! :)
73 Gareth G0MFR0 -
Ok well done Gareth. Yes, I saved the CAT, DAX and SSDR settings files to an external drive. Also I do a daily back up. And have system restore on. I also had the reboot hiccup, in my case following the W10 June culmulative update to 21H1. With these safety nets I was back up in 2-3minutes 😊
73 de Erik.
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
