New 6400M - 2 questions
After a day operating, I have two 'issues' that I would be grateful for help with.
1 When in SmartControl and tuning a band with the radio VFO knob, although the frequency changes smoothly as seen on the radio, in SmartSDR it is 'jumpy', not smooth. I am on 10Hz tuning step though the step size doesn't matter. It seems the display has a fractional lag.
2 When Txing FT8 I am perfectly decoded, but if I monitor my signal I hear ususally two scratchy sounds during a 15 second transmission. There is also a coincidental momentary jump on the panorama display. It is some kind of artifact. I cannot cure it.
The radio is connected to the computer (which a fast one Ryzen 5800X, 16GB RAM, high end graphics) by ethernet cable.
Anyone any ideas please? Thank you de Erik EI4KF.
Best Answers
Hi Eric
It sounds like a loose connection, but its all digital with Dax, so I dont worry about it too much.
The problem with making several changes at once and then finding that a problem has gone is not knowing what it was exactly that cured it. I did not have the problem at all yesterday and again not today. So I undid all changes, mostly regarding improving latency in the computer which I see now did not help. However, in my case, what effected the improvement was making a change in the FT8 software moving Split Operation from None to Fake It. When I returned to None, immediately the issue came back. I could see it in the panorama, hear scratchy artifacts twice per 15 second TX in the headphones and, on another radio, I heard two brief clicks. Put that setting back to Fake It and none of observations are present. I don't know why but it's good that its gone - hopefully permanently but time will tell.
That would be a good test, or listen to the flex on a websdr radio. The monitor function doesn’t use the output of the transmitter. Also, it is possible to set up a receive only antenna to the rx port and use full duplex mode. There is more on this in the manual.
Don't forget, you don't need a WebSDR to listen to yourself. You have multiple receivers in your Flex radio to listen to yourself.
Full Duplex (FDX) is a very powerful tool that your FlexRadio has. Something that no other radio has.
No 1 is solved. It was caused by using AutoCenter 3rd party software. Turn that off and everything is silky smooth.
So its the scratchy noise that occurs sporadically during FT8 transmission that I need help with if anyone has any ideas.
Thanks, Erik.
I occasionally get the scratchy sound on monitoring my Ft8 transmissions too. Dont know what is causing it.
Hi Wayne. I thought it was a constant problem, having just acquired the radio and faced with it immediately. Actually it is as you state, occasional. I am not going to worry about it too much.
What version of Firmware are you running
most of the Older versions had issues with DAX getting statically after a few hours and just a DAX restart fixed it.
if it is not DAX then you can try shutting down the radio and remove the DC power it off for a couple minutes then power it back on
if that doesn’t work then last but not least do a hard reset on the radio
Im running the latest 3.2.39, but havent noticed it yet.
Its always been intermittent
I am on the same of course as its a new radio. I must say I haven't noticed it today.
How. are you monitoring the transmit signal?
Just with monitor turned on and through the speakers. Probably should try turning one of the other transceivers on and try that
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
