FT8 transmitted signal
I have just acquired a new 6400M. My first venture with it is FT8. On transmission I am rather alarmed to see this:
I have all these side bands either side of the transmitted signal. For the life of me I cannot work out what I have done wrong. Can anyone help please? Thanks Erik EI4KF.
You need to show a screen shot with the measurement points on the right side of the graph.
If you are zoomed in, this could be a normal view especially if you are showing down to -120.
Hello Mike.
The TX Gain is at 45 and the Level Meter shows about -8. Is it ok or am I transmitting a bad signal, which is my concern?
Thanks de Erik.
Hard to tell without picture of whole SmartSDR screen but judging from your first picture and then second picture the primary signal is more than 60 dB above the other “peaks”. This does not reflect your actual transmitted signal out over the air but based on what I am seeing it looks normal.
you could look at your signal over the air using a web SWR receiver or ask someone with a Flex to do a screenshot of your signal.
Thank you Dave. I have managed to improve it, not sure how except I did a reboot. I can see that you are right and it is not being transmitted.
- 391 Community Topics
- 665 The Flea Market
- 166 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
