sainsmart relay module
Dave K9UK
I use an 8-relay module of that kind to control 120 volt devices with a RPi - works quite well. Not being used for my Flex. I drive the logic with 3v and the relays with 5v.
I have used the SainSmart USB-8 module direct from the Flex. I used it as a bit cable device for antenna switching before I purchased the 4O3A 2x8 antenna switch.
This is the module I used.
I have a Denkovi usb 8 relay board but have a use for at least 11 relays -- Just trying to put everything on one board --
Dave - K9UK0 -
I have used the Denkovi relay board and the Sainsmart relay board, both work fine as my antenna switcher by frequency.
Drives one of the 5 position remote antenna switch my MicroHam. Jim K4JAF
This has been a great discussion, I have the Sainsmart board purchased from Amazon and will be doing the hookup in the next few weeks.
from reading this discussion I am anxious to get started. I have found there are many more things it can be used for than expected.
Paul
KR5OG
One more comment, I had used the USB-8 board plugged into the Flex to drive a W2IHY 1x4 antenna switch. With a small experimenter's box, cable and connectors I had a 4 port automatic antenna switch that followed the Flex for under $200 total.
ok - Here is the plan -- I am ordering the Sainsmart usb 16 relay board on Amazon and will be testing when it arrives -- Let you know
Thanks all for the comments,
Dave k9uk1 -
So it seems dangerous to use this with a PI vs the Flex. I read that it resets the relays multiple times on reboot (usb version)
"When the board is connected to the PC while PC is restarted, the relays will be toggled several times which because of the structure of the FTDI chip."
How do you avoid transmitting into a grounded or open antenna port?
My application is to have the relay board feed an antenna switching network (a diode matrix to sixpak) -- I will connect the board directly to the usb port on the Flex and let the Flex determine by band what relay is selected. I have not received the board yet but that's the idea if it works :).
Sainsmart relay board (usb 16 relays). Tried and failed. The Flex did not recognize the board. Had no problems with the Denkovi 8 relay board and if my project continues I will just have two Denkovi boards instead of one board with 16 Relays. Lesson learned.
Six Months Later... Beginning of JUNE 21 hopefully those in the know still following. I managed to pick up an enclosed KK1L 2X6 Port Antenna Switch that was hooked to a Printer cable to a manual switchbox with Channel 1-6 center off radio A or B toggle switches. So I can manually select any of the ports on the KK1L board. But not auto select a B radio side in SO2R automatically or select multiband antennas.
Trying to automate... I picked up a SainSmart 8 port board this week and it showed yesterday... Clicks fine in the bit mode, and I will have zero issues getting the Single band antennas to switch by the correct relays. MY PROBLEM? I have only two single band antennas. a 6 meter beam and a 17M beam. The other antennas are a tribander and a Doublet that fills in for everything else 80-60-40-30-and 12m... My channels are assigned 0= 6M, 1=17m beam, 2= tribander, 3 =Johnson matchbox with the 135' CF doublet for 80-60-40-30-12m
I'm scratching my head as to how to get those multiband antennas to switch. OH I could go to antenna channel 2 on the FLEX 6500, but I have no way to select FREQUENCY CONTROL and exclude 17m as it is in the middle of the tribander, or the doublet frequency would only work 80-30 and exclude 12M... I'm not trying to use this board for SO2R just switch my antennas... Of course manual works peachy...
Erika DD
Erika,
I have a solution for you but just going to bed (12:35 a.m.). Ham fest tomorrow so 5 hrs sleep before getting up.
Email me direct to remind me. I have a SainSmart USB 8 and can explain how I jumpered it to do what you want. My email good on QRZ. I will also post the solution on here for others to see as well. I’ll include my cell with my reply to your email.
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
