PGXL Clicking
In the last 2 weeks I have been hearing a clicking or creaking sound every few seconds after the amplifier gets warm. Usually around 60 degrees C range. The amp was received March 1. Power output is fine, I usually run it around 900- 1000 watts out, although it will easily run 1500 watts on all bands. I attribute this to normal thermal expansion and contraction. Should I be concerned? Does anyone else have a similar observation?
73, Bill NE1B
Hi Bill,
I hope you are doing well.
My PG XL “clicks” when cooling down. It appears to be thermal expansion/contraction as you suspect. I received the amp here at home in April. It seems to be settling in and I do not notice it (or I just haven’t been listening for it). I can’t answer for the PG XK at my remote site as I am not there to hear it.
I hope to move that setup to another tower site and will test when I do get to the remote site for maintenance,
Thanks Dave! Yes, same on warm up and cool down cycles. I was wrong on the date. Mine was also the first week of April 2021, not March. I have been using it so much chasing DX on all bands that it seemed longer! It has been flawless and having great results! The only "feature" I would want added is a power down/power up feature. That will have to be external on the 240 Vac.
Bill
I also get the clicking when cooling down and first thought it was relays clicking in to vary the speed of the fan but thermal expansion/contraction makes more sense as you would think fan speeds would be done without relays.
Man, just lovin this amp. 😍
The amp is a beast!
I like the integration to the Flex ecosystem and look forward to the Tuner Genius. Radio - PG XL - TG XL - 2x8 switch. maybe splurge on some good bandpass filters if needed for SO2R contesting.
Just opened a ticket on this issue. They requested some additional info, I sent it, no word yet.
This sounds like thermal clicking on the heatsink. My OEM amp does this too.
Carefully turn the amp on its side and check all screws. I found some that were not tight.
[{"insert":"Mine is doing the same thing after TXing and cool down. Didn't do it for a month, now it's doing it. \n"}]0
No any clicking here
Mine is clicking still on warm up and cool down. Even after replacement of the blown LDMOS (dis-assembly, re-assembly)at the factory. I am now running the "C" mode all the time and watch the temperature range. My T11 higher VSWR Log Periodic (1.5:1), on 6 meters, heats up faster than my 6M7 M2 (1.2:1), so I try to keep it below 70C.
Mine is clicking as well on warm up and cool down at about the same temp on warm up and cool down. It appears to be doing this when the fans change speed for temp change. Can we get a verification that this is normal or does it have a issue.0
This is normal. Thanks to thermal dynamics, when the heat sink gets warmer, it gets bigger. When it cools down it gets smaller. It is to be expected as the physical movement can cause a clicking as well as the heatsink expands and contracts.
I hear this in OEM amps as well that I own. And, it is nothing to be concerned about.
Michael, Should I open a ticket as mine is not clicking? :)
You aren't working it hard enough! :)
G'day Mike
I have a PGXL here that was on the Christmas Island DXpedition. An otherwise perfect amp, it clicks as well. This video was taken some minutes after a couple of 'audio's at about 1200w. The temp of the PA was about 43deg. I am not sure the noise is coming from the heat sinks. Seemed to be somewhere behind the power supply module. Keen on your thoughts.
https://drive.google.com/file/d/1ML5UqMtz0Hlxe37IDSuQ2Zlyz9l_88tw/view?usp=drive_link
The clicks happen at about 38s, 52s and again at about 2m25. Apologies for the other noises. I live in a 100yr old house and the old sash windows get quite a rattle up on a windy day.
Aaron
VK2ON1 -
Hi Aaron
You should open a support ticket as they will know what that might be.
- 112 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
