FT8 randomly stops transmitting
Yes Brian, and setting up the COM port using FlexVSP. Haven't seen a lockup TX since doing that.
Thanks Doug. I will try doping the same. Hopefully the bug in the WSJT-X driver for the Flexradio 6xxx series will eventually be fixed - let's see what 1.10 (now in Beta) does.0
Hi I recently had very similar issues with the wsjt-x when it suddenly stopped transmitting. I also had some cat errors when trying to change frequency. I'm not sure if you all have looked at your dax drivers.
I had noticed that there was a recent windows upgrade. My dax drivers looked like this
This is the way it is supposed to look. After much uninstalling and manual removal and installation of DAX files I got it to look like this and my issues went away
By the way the first pic wa after I had removed a bunch of ghosted and other DAX drivers. They are supposed to look like the correct list and be in the same order. If some have gone to a new computer and installed Smart DSR this could give you a fresh set of correct drivers.
73 ray0 -
I have an odd situation. I had no problems with setting up my 6300 on FT8. Using DAX and Slice-Master. I want to use my iPad, so I set up Parallels Access. It was fine for one evening and then it stopped transmitting only with the iPad. On the computer itself, it works very well. I noted that the PTT is triggered, but there is no audio. Any ideas? Interesting, I changed to JUMP desktop and it works fine. Parallels runs the apps through their software; Jump is a mirror0
I've got the same problem with a new icom 7300 and running a mac mini0
I've got the same problem with a new icom 7300 and running a mac mini and I'm running the news version0
[{"insert":"I have almost same problem when I am go with high power WSJTX switched of and say reconfigure. Think RF interference is doing something on computer \n\n"}]0
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
