FT8 randomly stops transmitting
Yes Brian, and setting up the COM port using FlexVSP. Haven't seen a lockup TX since doing that.
Thanks Doug. I will try doping the same. Hopefully the bug in the WSJT-X driver for the Flexradio 6xxx series will eventually be fixed - let's see what 1.10 (now in Beta) does.0
Hi I recently had very similar issues with the wsjt-x when it suddenly stopped transmitting. I also had some cat errors when trying to change frequency. I'm not sure if you all have looked at your dax drivers.
I had noticed that there was a recent windows upgrade. My dax drivers looked like this
This is the way it is supposed to look. After much uninstalling and manual removal and installation of DAX files I got it to look like this and my issues went away
By the way the first pic wa after I had removed a bunch of ghosted and other DAX drivers. They are supposed to look like the correct list and be in the same order. If some have gone to a new computer and installed Smart DSR this could give you a fresh set of correct drivers.
73 ray0 -
I have an odd situation. I had no problems with setting up my 6300 on FT8. Using DAX and Slice-Master. I want to use my iPad, so I set up Parallels Access. It was fine for one evening and then it stopped transmitting only with the iPad. On the computer itself, it works very well. I noted that the PTT is triggered, but there is no audio. Any ideas? Interesting, I changed to JUMP desktop and it works fine. Parallels runs the apps through their software; Jump is a mirror0
I've got the same problem with a new icom 7300 and running a mac mini0
I've got the same problem with a new icom 7300 and running a mac mini and I'm running the news version0
[{"insert":"I have almost same problem when I am go with high power WSJTX switched of and say reconfigure. Think RF interference is doing something on computer \n\n"}]0
- 393 Community Topics
- 669 The Flea Market
- 174 SmartSDR+
- 452 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 75 Aurora
- 318 FLEX-8000 Signature Series
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 834 Peripherals & Station Integration
- 146 Amateur Radio Interests
