Using WSJT with Smartlink
CharlieW
I have set up WSJT on a remote computer that I use with Smartlink. It seems that in order to transmit I have to click on MOX. I have set up PTT and it is recognized by WSJT but it does not place my 6400 in transmit. I have to turn on MOX to transmit. The PTT works fine when using SmartSDR on the computer in the LAN.
When WSJT goes into TX it must go through SmartSDR CAT. Are you keying the radio via a PTT level (a 2nd CAT port) or via a CAT Command.
The short fix for you is to use SliceMaster to do your configuration for you.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
