Using WSJT with Smartlink
I have set up WSJT on a remote computer that I use with Smartlink. It seems that in order to transmit I have to click on MOX. I have set up PTT and it is recognized by WSJT but it does not place my 6400 in transmit. I have to turn on MOX to transmit. The PTT works fine when using SmartSDR on the computer in the LAN.
    edited May 2021
    @CharlieW
    When WSJT goes into TX it must go through SmartSDR CAT. Are you keying the radio via a PTT level (a 2nd CAT port) or via a CAT Command.
    The short fix for you is to use SliceMaster to do your configuration for you.
