PGXL Input Power Protection
If the PGXL is connected to a Flex 6600 that is set to 100 watts output, does the PGXL have circuitry to automatically reduce the input power?
I know I can use the TX setting tab in the 6600 to limit the power automatically to the amp, but I would like the ability to operate the 6600 at 100 watts without turning on the amp and putting it in standby. If I limit the power on the 6600 power using TX Tab for the amp, I would have to change the setting each time I use the amp or to work barefoot.
I currently use DDUTIL with my KPA500, but I really don’t want to have to rely on third party software to provide input power protection in the event I forget to reduce the power to the PGXL if I purchase one.
Reggie
N3OP
Yes. You will get a warning and it will save itself. I do it by accident all the time.
If you want to automate your power, FRStack will do what you ask.
Mike va3mw
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
