PGXL Input Power Protection
If the PGXL is connected to a Flex 6600 that is set to 100 watts output, does the PGXL have circuitry to automatically reduce the input power?
I know I can use the TX setting tab in the 6600 to limit the power automatically to the amp, but I would like the ability to operate the 6600 at 100 watts without turning on the amp and putting it in standby. If I limit the power on the 6600 power using TX Tab for the amp, I would have to change the setting each time I use the amp or to work barefoot.
I currently use DDUTIL with my KPA500, but I really don’t want to have to rely on third party software to provide input power protection in the event I forget to reduce the power to the PGXL if I purchase one.
Thanks,
Reggie
N3OP
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYes. You will get a warning and it will save itself. I do it by accident all the time.
If you want to automate your power, FRStack will do what you ask.
Mike va3mw
- 322 Shack Infrastructure
- 227 Networking
