Smart Link Login just says OK
Hi
Just got my 6700 back from Flex for some repairs and upgraded to Version 3.2.34.
I enter Smartlink Log IN and it says OK and nothing happens.
Read the old threads and rebooted both the 6700 and Router + PC any idea's
Ian
Well it just keeps getting better I now also see my COM ports are gone and I have retained them in Device manager.
I had this one other time don't remember the cure.
Ian
Latest Updade
I removed all the previous Flex Smart SDR versions as I don't use them. Did a complete reinstall of Smart SDR 3.2.34.
Checked the Virtual Com Ports showed no ghosts left behind and created all new Ports. Radio seems to be working OK.
I Still can't get the SmartLink to Log In it just say's OK.
Any Thoughts???
Ian
There should be a way that we can see if the SmartLink is up or down can you pass this along for development.
Ian
Ian
Done
I still have the same problem, just get the ok response but nothing else...inspite of Mike-VA3MW announcing the problem is solved...?
Many thanks for all your help and looking forward to hear from you
Francesco Doenz HB9GUO
Morning Mike and Flex Tech's.
I am currently experiencing the same "OK".
Kevin, Va3KGS
Im having this issue on May 17th. Any update?? I cant believe that this is on going for this long!!
Please check the annoucements for the details and status please.
As a quick FYI, we have the problem solved in the lab. We are currently working on the delivery packaging and that is a complicated process to make it as streamlined as possible. When then need to pass that through our QA process.
This is not a quick fix and we are sorry for any impact you are seeing.
- 361 Community Topics
- 620 The Flea Market
- 8.1K Software
- 38 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 983 Third-Party Software
