Smart Link Login just says OK
Hi
Just got my 6700 back from Flex for some repairs and upgraded to Version 3.2.34.
I enter Smartlink Log IN and it says OK and nothing happens.
Read the old threads and rebooted both the 6700 and Router + PC any idea's
Ian
  • KM4CQG
    KM4CQG Member ✭✭
    Well it just keeps getting better I now also see my COM ports are gone and I have retained them in Device manager.
    I had this one other time don't remember the cure.
    Ian
  • KM4CQG
    KM4CQG Member ✭✭
    Latest Updade
    I removed all the previous Flex Smart SDR versions as I don't use them. Did a complete reinstall of Smart SDR 3.2.34.
    Checked the Virtual Com Ports showed no ghosts left behind and created all new Ports. Radio seems to be working OK.
    I Still can't get the SmartLink to Log In it just say's OK.
    Any Thoughts???
    Ian
  • KM4CQG
    KM4CQG Member ✭✭
    There should be a way that we can see if the SmartLink is up or down can you pass this along for development.
    Ian
  • KM4CQG
    KM4CQG Member ✭✭
    Ian
    Done
  • Francesco Doenz
    Francesco Doenz Member ✭✭
    I still have the same problem, just get the ok response but nothing else...inspite of Mike-VA3MW announcing the problem is solved...?
    Many thanks for all your help and looking forward to hear from you
    Francesco Doenz HB9GUO
  • Kevin Va3KGS
    Kevin Va3KGS Member ✭✭
    Morning Mike and Flex Tech's.
    I am currently experiencing the same "OK".
    Kevin, Va3KGS
  • Mike KD2CJJ
    Mike KD2CJJ Member ✭✭
    Im having this issue on May 17th. Any update?? I cant believe that this is on going for this long!!
    Please check the annoucements for the details and status please.
    As a quick FYI, we have the problem solved in the lab. We are currently working on the delivery packaging and that is a complicated process to make it as streamlined as possible. When then need to pass that through our QA process.
    This is not a quick fix and we are sorry for any impact you are seeing.
