Did the API change?
For some reason, when connecting a non-GUI client to my Flex 6400, I can no longer load a global profile unless there is already a GUI client connected, or if I connect as a GUI Client. I am pretty sure this worked before. I am not sure that I tested this on 3.2.31, so it may have changed then.
Example of the profile command:
fRig.send("profile global load \"KD0RC - 20 SSB\"");
Just to be clear, if there is a GUI client (like SmartSDR) connected, I can use the following commands, and the above command works perfectly:
fRig.send("client gui KD0RC_TeensyMaestro");
fRig.send("client start_persistence 1");
If the same profile global load command is issued when connected as a plain client (i.e. a client gui **** command was not issued), then the profile is not loaded. I do get the correct list of global profiles back in any case.
To approach the problem from a different perspective, is there a way to query for a connected GUI Client? That way if none are found, I can connect as a GUI Client.
Any thoughts or ideas?
Best Answers
Len, I might ask that you open a support ticket on this.
Put in a help desk ticket and Tim got back to me right away. The API is fine - my personal testing habits could use some work...
I thought that I could load a profile with my TeensyMaestro without SmartSDR running when I was on 3.1.12, but I just verified that I never could do that. When I did my testing last year, I was so sure that I tested that, but I obviously didn't.
Anyone with a Teensy Maestro who wants to run standalone (i.e. no SmartSDR connections to the radio), just needs to hold any button during powerup to put it into GUI client mode. This then allows you to select and load profiles.
Thanks again for the fantastically quick (and accurate) response Tim, I really appreciate it.
I think the Vanilla bad word filter is set a little tight... In my post above, the asterisks filtered out three "x" characters in a row indicating freeform text. If there is a way to loosen up the filter a bit, I would appreciate it. Obvious candidate words should stay, but common terms in the context of ham radio like "k.i.l.l the power before opening the case" are currently being asterisked out, making it look like the author was saying something inappropriate.
OK, thanks Mike, I sure will.
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
