Band buttons don't work
Wow, not sure what is happening there. You might want to try this: Use the band control to go to 40. Now click on the frequency shown on the "flag" and type in an 40 M freq. Now click to another band and then back to 40. Did the radio return to the 40 M freq you just set? If so, then that might be the way to get each band to pop up correctly.
If that does not work, I would suggest submitting a help desk ticket. Someone from Flex should be able to diagnose your issue.
Thanks. Your suggestion did not work, but I did the factory reset procedure and it seems to have fixed the issue. Very weird! I want to love the flex radio but this was a sour start to my experience. Hopefully it doesn't happen again0
OK great, I'm glad that was all it was.
Not really enough information. Are you using SmartSDR, SmartiOS, Maestro or is it a 6600M? I have a 6600 and have never seen any problem switching bands when pushing the band buttons on each of those control modes mentioned.
Bill, NE1B
SmartSDR for Windows. 6600 (Non-M) So far its been okay0
Yes, the factory (white power button) cues much weirdness. Don’t know what happens, but I have had the same situation.
Glad you got it sorted out.
As others have mentioned it is good to tell the entire story and screen shots are really really helpful.
We also have a LOT of instructional videos on YouTube that are targeting for the new user.
Thanks! I was about to record a video for this issue before I did the factory reset, so far its been working great. :)1
Okay! I was able to reproduce my issue. If I zoom all the way out on the panadapter so I can see the most bandwidth and scroll up and down the bands, it seems to make the last band button I pushed not work. I recorded a video of this issue this time. https://youtu.be/yYAX7m-cd10
I was able to fix it this time by restarting SmartSDR, but the first time I had to reset the radio.. weird0 -
I have found this also. If you scroll way out on a band and then switch to a different band it will **** up the band switch.
Bill AB7AA
This deserves a help desk ticket so flex can research and track it. Probably won’t get fixed, but at least they’ll know.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
