No reception on 6500
Jan on8aj
What is wrong? was doing CW on 20m (remote) good reception but very high audio tone. radio rebooted in an attempt to restore the audio tone. But no more receiving any signal at any band (steppir DB42 connected) Started smart sdr on PC at radio side with teamvieuwer, same there so i guess hardware have serveral antenna's , all the same not a beep.
Best Answers
Hi Jan, I know that you are remote, but if you can get to your radio site, try moving the antenna to ANT2. If that works but ANT1 does not work, then it sounds like a hardware problem with ANT1.
Another thing to look at is the connections and cabling between the radio and antenna. You could try temporarily moving the antenna to RXA to be sure that the antenna and cabling are OK.
@Jan on8aj Can you include a screen shot of SmartSDR please. It really helps to diagnose your situation.
How do i reset the radio, i have only control over the 12v dc power supply and the remote on/off on the back of the radio. If i need to go and puch some buttons manually, i'll drive there tomorrow.
Thanks Jan0
Can't edit my own post... I can receive on my RX antenne , ant 1 no TX en no RX, ant 2 is not connected, trnsverter is working in TX & RX0
Thanks!
Can you try 1 more thing. Please export your profiles and do a database reset on the radio and then see if it works as you expect.
Let me know.
I have only control over the 12v power suply (on/off) and the rear on/off switch. If i need to push some buttons manually i drive there tomorrow. Thanks for the help!0
Been to the remote lacation. Pressed OK button and power on until the white light came on. Let the radio start up, no difference. Changed antenna from ouput 1 to output 2, no difference either. Hooked up my icom ans searched for a strong signal, found 9a station on 14.254 with 59+ signal. Antenna back to the flex, VFO to 14.254 but noting, no reception at all. Also no power, not on antenna A and not on B (photo taken on RX ant)
I have opened a support ticket for you
This discussion has been closed.
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 783 Peripherals & Station Integration
- 997 Third-Party Software
