Display setting goes to 1/1/1 each time.
With my remote 6500, panadapter display setting behaves strange and goes to 1/1/1 not showing waterfall each time opening the panadapter with v3.2.31.
I do not observe such panadapter display problem with my local 6600 with v3.2.31 nor 6500 with the previous version.
Is it because of an inadequate updating? I tried updating/downgrading few times, but it does not solve the problem.
de JA2IYJ, JI1BNU
Ken Yamada
Best Answers
Hi Ken
This sounds like an issue that a database reset might fix. Make sure you back up your profiles first.
In the second display, note that the waterfall rate is 0 and the black level is not AUTO.. This typically happens when the database has not been reset during the upgrade process. Export your profiles and perform a factory reset, then import the profiles.
AL, K0VM
Sorry for late to respond.
Yes, it solved the problem, hard reset and re-install.
It took us time to take Flex6500 from remote site to the home shack and hard reset/re-install.
Thank you!
de JA2IYJ, JI1BNU
Ken Yamada
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
