N3FJP Voice Keyer
Cy Stanway
Anyone get the N3FJP voice keyer working with their 6400? I chose a new CAT (CAT 17) but it won't key the radio. Can't be that hard but I haven't been able to figure it out.
I have not been able to get the voice keyer to work either. However, it does key the radio but I get no transmit audio. To key my 6400M I select the same CAT serial com port that I have set up for keying CW. I suspect I am not selecting the correct DAX audio input to transmit the recorded voice although I have tried different ones. Please let the group know if you get the N3FJP Voice Keyer working correctly.0
I think you need the ptt option, not cat for keying the rig, or maybe select vox as an option..
I have the N3FJP voice keyer working now. I am using a CAT Serial Port #7 to key the Flex 6400M and I have selected the DAX Audio TX (FlexRadio Systems) to feed the recorded audio files to the Flex. I have attached two screen shots to better explain the settings.
3 -
Thanks!!!
This does not appear to work with using PC Audio. DAX needs to be enabled to transmit the recording, then disabled to transmit from the PC.
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
