N3FJP Voice Keyer
Anyone get the N3FJP voice keyer working with their 6400? I chose a new CAT (CAT 17) but it won't key the radio. Can't be that hard but I haven't been able to figure it out.
I have not been able to get the voice keyer to work either. However, it does key the radio but I get no transmit audio. To key my 6400M I select the same CAT serial com port that I have set up for keying CW. I suspect I am not selecting the correct DAX audio input to transmit the recorded voice although I have tried different ones. Please let the group know if you get the N3FJP Voice Keyer working correctly.0
I think you need the ptt option, not cat for keying the rig, or maybe select vox as an option..
I have the N3FJP voice keyer working now. I am using a CAT Serial Port #7 to key the Flex 6400M and I have selected the DAX Audio TX (FlexRadio Systems) to feed the recorded audio files to the Flex. I have attached two screen shots to better explain the settings.
3 -
Thanks!!!
This does not appear to work with using PC Audio. DAX needs to be enabled to transmit the recording, then disabled to transmit from the PC.
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 473 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
