AM Broadcast Interference on my Flex 6400
Here are a couple of links to help build your own. In a quick search, I did not see any commercial units that are capable of handling 100 W transmit power, but I would be surprised if there are not some available somewhere...
https://www.nutsvolts.com/magazine/article/filter-design-software
Thanks Len - since asking, I did a search and found one from Morgan KF7P and another from DX Engineering - both rated for 200W - may give one a try or whip one up myself - the 6400 is amazing sensitive (no complaints there)!0
Broadcast Band Filters good for over 100 watts at
https://www.kf7p.com/KF7P/Morgan_Filters.html
or
https://www.dxengineering.com/parts/dlw-fl1718
I've used both at various times to cut down AM Broadcast interference.
Mark K6UFO
Thanks Mark
Leaning towards the Morgan
Michael
W7HUT0 -
Thanks Mark
Michael
W7HUT0 -
The company I worked for has used the DX engineering brick wall filter (when it was hand built by the designer) for installations of military radios that were suffering from proximity to an AM station. It was a 150 watt radio and mostly used for digital comms. The filter worked very well.
You also might look into notching the worst offender. A series cap and inductor to ground works.
Steve KD2OM
Thanks Steve - Have the Morgan on order, we'll see how it works...
Michael W7HUT0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
