No TX audio on LTE
I am having an issue with Smart SDR for the iPhone. When I am at home on my LAN everything works fine. When I am on LTE I can connect to the radio and listen but have no TX audio. If I connect my laptop to the hotspot on my phone it works fine. I have checked that I am using the right mic on the phone and have allowed access to the mic in the iPhone settings. I have checked my port forwarding and it is fine. I have connected to a friends flex on my iPhone and it works fine.
Any thoughts?
Chris
Ki1p
  • aa3ssradio
    aa3ssradio Member ✭✭
    Have the same problem with mine on Sprint. My audio is intermittent. Sometimes it works other times it does not work. If I use a hotspot and connect to the hotspot's wifi it works but won't work direct on LTE on iPhone
    @Chris Knox I opened a support ticket for you.
  • [{"insert":"Thanks Mike \nI am working with Ken Wells now.\ndefinitely an odd issue \nI will let you know if we figure it out \nthanks\n"}]
  • N8RQJ
    N8RQJ Member
    [{"insert":"Any word on this?\nIm having the same issue. I can actually see my audio peaks in the meter\nbut nothing transmitting from the radio. \nThe radio keys but no output.\nCWX works but no SSB. \nVery frustrating. I bought it just for remote access \nand can’t do it with my phone.\nI also checked that DAX is off I selected iPhone and can see my voice peaks on the meter.\n\nThanks,\n\nHarold Johnson\nN8RQJ\n"}]
  • N8RQJ
    N8RQJ Member
    [{"insert":"Please disregard my post I fixed it by updating firmware on my router thanks\nHarold\nN8RQJ\n"}]
