Transmit lock when using "Send CW"
schacterfoto
I use a 6400M with an RM Italy HLA 305 amplifier operated via PTT. I have set up an automated CW message "RIG IS FLEX 6400M PWR". After "PWR" I cut in manually with my actual power level and antenna info. I've noticed that if I start manual transmission too soon after the message ends (to make it sound seamless to the person at the other end) the rig locks up in TX and will not revert to RX. Problem is solved by waiting a beat (say, half a second) after the automated message concludes.
I think something is 'wacky' with sending the macros. I have an issue as well. Flex jumped into the thread for help and then went dark after a few back and fourths. I still have the issue and you can view my thread here: https://community.flexradio.com/discussion/8023143/cwx-bug-no-audio-or-sig-after-macro-abort#latest
The workaround is to just let the macro fully complete. That works (somewhat) for you because you are at the natural end of your macro.
GL!
Pat - w5wth
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
