No TX audio on LTE
Chris Knox
Member ✭
I am having an issue with Smart SDR for the iPhone. When I am at home on my LAN everything works fine. When I am on LTE I can connect to the radio and listen but have no TX audio. If I connect my laptop to the hotspot on my phone it works fine. I have checked that I am using the right mic on the phone and have allowed access to the mic in the iPhone settings. I have checked my port forwarding and it is fine. I have connected to a friends flex on my iPhone and it works fine.
Any thoughts?
Chris
Ki1p
Any thoughts?
Chris
Ki1p
Have the same problem with mine on Sprint. My audio is intermittent. Sometimes it works other times it does not work. If I use a hotspot and connect to the hotspot's wifi it works but won't work direct on LTE on iPhone
@Chris Knox I opened a support ticket for you.
[{"insert":"Thanks Mike \nI am working with Ken Wells now.\ndefinitely an odd issue \nI will let you know if we figure it out \nthanks\n"}]0
[{"insert":"Any word on this?\nIm having the same issue. I can actually see my audio peaks in the meter\nbut nothing transmitting from the radio. \nThe radio keys but no output.\nCWX works but no SSB. \nVery frustrating. I bought it just for remote access \nand can’t do it with my phone.\nI also checked that DAX is off I selected iPhone and can see my voice peaks on the meter.\n\nThanks,\n\nHarold Johnson\nN8RQJ\n"}]0
[{"insert":"Please disregard my post I fixed it by updating firmware on my router thanks\nHarold\nN8RQJ\n"}]0
- 382 Community Topics
- 632 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 40 Aurora
- 953 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
