No sound from the monitor
As a former broadcaster, I am used to hearing myself talk. The monitor function worked on my 6500 at first even though I had to have the monitor turned almost wide open.
So maybe it was a hardware issue. Now I have a 6600M and I still have no output from the monitor. (Yes, my headphones work fine for receiving.) I have not found any settings that affect this and the manual has only a paragraph about the monitor function. (I do realize I can only hear how the radio sounds by recording it and that works fine.)
Hi Terry, I have no problems with it on my Flex 6400. Are you operating remotely via SmartLink or local? Are you using headphones plugged in to the back of the radio or into the PC? What level do you have the Monitor set to? With headphones plugged into the radio, I have to set the monitor level significantly higher than when I use my amplified speakers (30 vs. 75).
Where do you plug in your mic, PC or back of the radio? I don't think the monitor function works if the mic is plugged into the PC.
Len, KD0RC
Hi Len, Thanks for responding. I am operating locally. Headphones and mic are both plugged into the back of the radio. The monitor level is set to wide open. I have a friend with a 6600M and his monitor is working fine. My setup seems to match his settings. I've talked to Flex about it and the question is kind of getting down to, is it so much of a problem to justify sending the radio to Austin. The are other ways to monitor my audio (input) by putting the audio through my PC. Of course, my 6600M is out of warranty. The funny thing is my monitor 6500 worked for a period and then it quit. Which made me think it might have been related to an update but that has been pretty much ruled out.
What's your plan for the Miny Maestro. Are you planning to monetize your project in some way? (Plans, Kits, or an actual product)
Thanks again, Len.
Terry K8EET
Hi Terry, The TeensyMaestro is now available on GitHub. I am not going to monetize it - I don't need a business, I like retirement too much! Here is a link to the discussion. Steve, WW1SS is building one now and Dave, W4WKU has his built and ready for the NAQP contest this weekend.
TeensyMaestro — FlexRadio Community
Len, KD0RC
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
