What does this mean: "SmartSDR Client Connected from IP 10.0.0.151"?
K9TI
I keep getting the pop up notification "SmartSDR Client Connected from IP 10.0.0.151" every 5 seconds. What is causing this and what is it? I apologize if this is a simple question but I am not that much of a computer person. Thank you for your assistance.
73, Brian K9TI
73, Brian K9TI
What do you have for any accessories with your Flex? A description of your station setup will help troubleshoot the message you are seeing
I got the pop up from my Antenna Genius 2x8 switch every few seconds until I updated the firmware on the 2x8 switch.
[{"insert":"I have an Antenna Genius, PGXL, and I use N1MM and Grid Tracker with Smart SDR. My antenna tuner is the Palstar Auto Tune but I use the RF sensing and not the RS232. Thanks Dave! \n"}]0
Hi Brian,
Try checking the IP address of your Antenna Genius from the Antenna Genius for Windows program ->options wheel -> device information -> Network Information ->IP Address. If it matches the IP address in the pop up notification (i.e.10.0.0.151) a quick fix is to re-boot the Antenna Genius switch from the AG for Windows program -> Options wheel -> configure device -> reboot device.
I noticed the recurring pop up starts happening if I start using SmartSDR and AG after Windows has been in screen saver mode.
GL!
John AF3K0
- 379 Community Topics
- 631 The Flea Market
- 120 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
