What does this mean: "SmartSDR Client Connected from IP 10.0.0.151"?
I keep getting the pop up notification "SmartSDR Client Connected from IP 10.0.0.151" every 5 seconds. What is causing this and what is it? I apologize if this is a simple question but I am not that much of a computer person. Thank you for your assistance.
73, Brian K9TI
  • David Decoons, wo2x
    What do you have for any accessories with your Flex? A description of your station setup will help troubleshoot the message you are seeing
    I got the pop up from my Antenna Genius 2x8 switch every few seconds until I updated the firmware on the 2x8 switch.
  • K9TI
    K9TI Member ✭✭
    [{"insert":"I have an Antenna Genius, PGXL, and I use N1MM and Grid Tracker with Smart SDR. My antenna tuner is the Palstar Auto Tune but I use the RF sensing and not the RS232. Thanks Dave! \n"}]
  • AF3K
    AF3K Member ✭✭
    edited January 2021
    Hi Brian,
    Try checking the IP address of your Antenna Genius from the Antenna Genius for Windows program ->options wheel -> device information -> Network Information ->IP Address. If it matches the IP address in the pop up notification (i.e.10.0.0.151) a quick fix is to re-boot the Antenna Genius switch from the AG for Windows program -> Options wheel -> configure device -> reboot device.
    I noticed the recurring pop up starts happening if I start using SmartSDR and AG after Windows has been in screen saver mode.
    GL!
    John AF3K
