Cannot Connect 6300 via SmartLink
Dave
N4CQ
Hi Dan
A couple of things you can check.
First, did you set up port forwarding in the router at radio end? If so, it is possible the radio’s local IP address has changed and the ports are not forwarded to the correct IP address on the network. I always do a DHCP reservation in the router for the radio’s MAC address so it always gets assigned the same IP.
Second, I have seen on rare occasion the need to reboot the radio. I have the ability to turn the DC on & off remotely if needed. I also have relays connected to the radio Remote On and across the PTT (in case I need to deregister or register on SmartLimk).
I also have a PC available on the remote network to TeamViewer into if needed. The PC is on a remote controllable outlet and bios is set to turn it on when power is applied.
After checking those things if it still does not work, open a Help Desk ticket.
Thanks for the feedback. Problem is solved. Unknown to me the account password changed. The account owner did not change the password either. The Owner logged off but could not log back on with what he thought was the correct password (same one I tried to use as well.) Resetting the password solved the access problem. No further action required.0
Glad you got it working.
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
