PSK31 and RTTY settings
I been looking for settings on the Flex 6500 for the proper audio ,
I just keep seeing problems , I don't have any problems with my 6500 works great !
I am running digital master 780 , my DAX is at 25 tx stream the power is like 80 watts , the mic shows -10
never hitting 0 Red.
But the sig color is red in the middle on the pan adapter . Where is the ALC threshold?
Maybe i am getting fooled by my display setting ?
Please provide your settings 100w max with a clean setting for clean signal , I don t want the digital kings freaking out :)
As you surmised , yes I think that you are being fooled by the display gain setting. Using WSJT as test signal source, if I turn the display gain up over 33 I get the red line that you described. I think that you are OK turn down the display gain to under 30.
Gayle K0FLY
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
