PSK31 and RTTY settings
I been looking for settings on the Flex 6500 for the proper audio ,
I just keep seeing problems , I don't have any problems with my 6500 works great !
I am running digital master 780 , my DAX is at 25 tx stream the power is like 80 watts , the mic shows -10
never hitting 0 Red.
But the sig color is red in the middle on the pan adapter . Where is the ALC threshold?
Maybe i am getting fooled by my display setting ?
Please provide your settings 100w max with a clean setting for clean signal , I don t want the digital kings freaking out :)
  • K0FLY
    K0FLY Member ✭✭✭
    As you surmised , yes I think that you are being fooled by the display gain setting. Using WSJT as test signal source, if I turn the display gain up over 33 I get the red line that you described. I think that you are OK turn down the display gain to under 30.
    Gayle K0FLY
